Kano Aerokroil
Kano Aerokroil
Not sure if anyone out there has used this lubricant before but it is the S***. I'm sure every car enthusiast has needed a good can of lubricant spray/ rust breaker. I'd have to say it works better than PB blaster or WD-40. Made my 02 housing swap alot easier. Not sure where to get it because we have it at the shop where i work, but the website is Kanolabs.com. Anyways, here's the info on the can in case you are curious.
*Loosens the toughest stuck together metal parts or your money back
*No harm to metal or skin, and prevents rust
*Use Kroil to loosen nuts, bolts, studs, screws, pulleys, shafts, bearings, guns, pipe threads, valve guides or any corroded metal parts.
*Removes rust, gummed oil, and grease, and cleans cement tools.
*Resists wetting so prevents rust
A scientific discovery reduces the surface tension so that this amazing solvent creeps into openings as small as one millionth of an inch. Wherever there is Corrosion- due to heat, salt water, chemical action, or weathering- Kroil will loosen metal joints in a few minute's time. Saving labor, equipment, and temper.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
