help!!/ a/c does not work when car is not moving
Old Sep 10, 2007 | 09:15 PM
Dont Try To Run's Avatar
Originally Posted by bluebyu36
take it out save some weight
You wont save a lot of weight unless you remove the compressor too... that is a lot of the weight in the system. Also, that would require a AC delete system i believe... = $$$ to sweat in your car... no thanks
Old Sep 10, 2007 | 09:29 PM
Cal City Evo's Avatar
Originally Posted by riceball777
first of all the ac does not work when the car is at idle, stuck in traffic of if the car is not moving. the ac will completely stop blowing cold and just will blow warm air.
but if the car is moving at least 30mph or more the ac is ice cold.
does any one else have this problem
You have a restricted air flow to the condenser. In it easiest sense the refrigerant doesn't have any way to release the heat when it goes through the condenser.
That is why it cools off when you start moving. Airflow over the condenser thus the refrigerant has a chance to cool. I figure you have upgraded your IC and thus making it that much more difficult for it to get rid of the heat. Meaning the condenser that is.
Old Sep 11, 2007 | 09:51 AM
bluebyu36's Avatar
lol ya i took mine out saved 40 pounds obviously with the compressor
dj_rock101
Feb 28, 2019 08:10 AM
SmurfZilla
Oct 12, 2013 03:46 PM
Havoc86
Lancer Troubleshooting
Aug 14, 2012 10:29 PM
idriveanevo
12
Jun 19, 2009 05:52 PM
fkw958
Feb 6, 2008 12:09 PM
