I Dont Know What Happened 2 My Clutch!
![Thumbs down](https://www.evolutionm.net/forums/images/icons/icon13.gif)
Ok, so im driving around and i stop at the red light. When im about 2 take off, i take my foot off the clutch and give it gas, but it wouldnt move. The clutch felt really soft and short.
I dont know if either the clutch is stuck or if i burned my clutch!
I made it to my friends house going at like 20 mph. But it feels like the clutch is not responding to the pedal!
I put it on 1st and totally let go off the clutch, and the car did not stall!
Anybody please help!!!!! what should i do?????
Did i really burn the clutch or is it just stuck?
check your clutch fluid. sounds like youre missing fluid and the clutch is just not popping back out. you may have a leak or it might just be low. if youre low you'll have to fill it and bleed it just like a break system.
Noticing that you have an 03, that must mean you most likely have some miles on your car. Either way you are going to spend some money. If you plan on going for some decent power later, get a twin and be done with it!
Most likely the clutch is dead. A second possibility is that your clutch is mis-adjusted and your throwout bearing isn't being allowed to unload fully.
Honestly with an '03 the clutch has probably just worn out.
