first start after cam install
i just installed hks 280s and the timing looked on so i tried to start it and it turned over almost started and backfired.
should i try to start it again or is the timing off
i need some tips on what to do next
california should i line everything back to tdc and try again
would the sensor being backwards cause this.
would it matter if my gas light is on and im on a slope.
Make sure the sensor is in properly. Also recheck timing marks. Thats all you can do. Did you bleed the lifters? You may have to do the lash adjuster procedure for a few minutes after the car warms up to get rid of the clicking noise as well. Id check the cam sensor first. When at TDC the smaller vein will be to the upper left, and the larger one will sit from 3 oclock to 6 oclock like this )
