Codes!!!!!!P0335!!! Help!!
P0335: Crankshaft Position Sensor Circuit
My car is throwing this code..
Is this mean my car is messed up or just some easy fix
Please Help and thank you in advance.
does ur car do anything weird?... the stupid code system just tells u it got a weird sensation coming from that sensor... if its just the light.. either clear the code or reset the ecu by unplugging the battery... weird for such a new car to throw that code though... prolly sumthin retarded... just clear the codes.. see wut happens
hey bro, i did a quick search, and this thread came pu https://www.evolutionm.net/forums/sh...ighlight=P0335
looks like they just cleared the code and changed the plugs, and it went away...i too had a code throw which was just the TPS issue, but thats when my UICP blew off, and car shut off....just put pipe back on and cleared the code....do you have access to a tacktrix cable?? if not, i guess you can goto a autozone to have it cleared for you..once you give it a basic tune up
Thanks guys.. I went to autozone and have them cleared that code.. And drove around the block for about 5 minutes at low rpm.. It hasn't came back on yet.
Thanks for the inputs and anymore are welcome...
Im gonna try to change out the plugs by monday. Hope it will cure it.
It scared the hell outta me tho lol
michaellw
12
May 5, 2016 07:21 AM
evolutionEvo
Dec 27, 2009 06:26 PM
rt turbo
17
Oct 16, 2004 05:04 PM
