apexi turbo timer help!?!
Old Sep 24, 2007 | 11:54 PM
gen3eclipsegt's Avatar
Question apexi turbo timer help!?!
right now i have the apexi turbo timer everything is hooked up and i want to hook up the a/f wire but which wire and wire color should i put it to off the ecu ????
Old Sep 24, 2007 | 11:58 PM
evo_tiago's Avatar
have a Greddy full auto. i never hooked mine to the ECU. works fine for me. So I never even bothered hooking it up.. good luck on ure info bro.
why do you wanna hook it up to the ECU? what diffrence would it do?just wondering.
Old Sep 25, 2007 | 12:03 AM
badstainless's Avatar
the a/f is setup for narrow band. I'm not sure what to do to make it wideband.
Old Sep 25, 2007 | 12:10 AM
would i have to tap off the white wire off my front o2
Old Sep 25, 2007 | 01:22 AM
boostless's Avatar
the white wire for the O2 sensor is what i remember. I downloaded the manual and looked at it. Ill double check and if you haven't found it ill post.
EDIT: It is the white O2 wire. It should be on the end plug opposite the largest plug top corner.
