wierd problem?(vid)
Old Oct 2, 2007 | 05:15 PM
bluebyu36's Avatar
wierd problem?(vid)
After the car is fully warmed up, this is what happens when i drive it at wot....or just hitting the gas in netureal as u see:
my mechanic says that he thinks it is the sender,that the guage is not working propely...i just dont want to overheat and blow up, plus i dont want to spend money on a sender if thats not the problem.i was thinking thermostat but he says he dont think so.......
Old Oct 2, 2007 | 05:26 PM
CrackerJackToy's Avatar
Im thinking it has to be the sender. Think about it... if a thermostat kept open, when you rev up, it should get hotter, not get extremely cold...
Its the sender of gauge malfuction. Go to mitsu and get a new one.
Old Oct 2, 2007 | 05:30 PM
billyblonco's Avatar
Its The Sender Or The Thermostat Is Stuck Open (did You Remove Your Thermostat)
Old Oct 2, 2007 | 05:39 PM
AJsGenerX's Avatar
Think of it as a water pressure gauge . Definitely check with Mitsu about the sender.
bluebyu36's Avatar
lol wierd wright, ya we pulled the thermostat and he said(racing results) it looked fine.....
Kordyte's Avatar
Are you running like 84 psi of boost? cause then you'd just be running out of gas
Old Oct 2, 2007 | 05:40 PM
bluebyu36's Avatar
24 (psi)on pump
ya we pulled the thermostat and i was about to change but the stupid autopart store gave me a lancer thermo..but my mechanic(racing results)said he highly doubt thats the problem he said the therm looked fine....
Old Oct 2, 2007 | 05:44 PM
bluebyu36's Avatar
anbody else..thanks for your help fellas
Old Oct 2, 2007 | 06:14 PM
bluebyu36's Avatar
dam nobody?
Old Oct 2, 2007 | 06:21 PM
Redlimit835's Avatar
me thinks sendunit or cluster short, my bets on a short somewhere in the sensor wiring.
my 2 cents
later
DJ
Old Oct 2, 2007 | 06:23 PM
MSFIT's Avatar
thats a weird problem, nice beats
Old Oct 3, 2007 | 01:55 AM
heavens turbo's Avatar
coolant temp sensor or computer or wiring problem. good luck.
Old Oct 5, 2007 | 05:50 PM
bluebyu36's Avatar
problem fixed thanks guys it was the sender
