Need help think i have a boost leak but not sure
I have a problem. I recently put my stock air box back in my evo 9. after i did this i believe i have a boost leak. whenever i get on my car in any gear everything works fine till around 5k or so then no boost and it takes forever to redline the gear. Also im hearing a weird noise when it gets to 5k or so, like a odd leaking noise which i never heard before. im sure this is a boost leak but not positive, plus i never had this problem before so any help will be appreciated. also one of the vaccuum lines got damaged when i was installing the stock airbox so i replaced it with a slightly thicker line could that cause any issues? thanks.
the snorkles on but the 2 bolts arent in (lost em) but would that really be creating this problem? if all else fails ill get the stock size line, but i feel something else is wrong...
nonojoe66
Oct 27, 2009 10:47 PM
roadace
Sep 24, 2005 11:04 PM
