Difference between BG and BGII?
Fomer Vendor
This probably won't be an issue with you, but in FL, with the heat, the tranny does not like the II. I have ran both, first 1, then I tried the 2, I went back to the 1. The differences are:
BG I: Works better when warmed up.
BG II: Works better cool (the first 5 mins. of driving in FL), once warmed its too slick.
I can't stand when people say only use Mitstubishi factory fluids. As long as you use GL-4 your fine. Shep uses a mixture of bgII and mt-90 and AMS uses all redline. I had my tranny, transfercase, and rear diff. fluid changed at AMS. They put mt-90 in the transmission, lightweight shockproof in the transfercase, and heavyweight shockproof in the rear diff. They also added some special additive to the rear diff. My car shifts like butter now.
EVOKing8
56
Jun 10, 2009 08:18 PM
