Difference between BG and BGII?
I'm looking at changing my transmission fluid and was wondering if there is any big difference between BG and BG II Synchoshift?
I did some searching, like I should have done in the first place, and came up with my answer. I tried getting some Diaqueen at my local dealership and they only have the large container so that is out of the question. It appears that BG II is fully synthetic and is just as good as OEM Diaqueen, if not better to help in 1-2 shifts and 5th gear grinds. I would prefer to buy something locally (Royal Purple, GM, Pennzoil) as opposed to ordering on-line and then having to wait for its delivery though.
I have been happy with BGII. Once warmed up my gearbox shifts very smoothly from 1 to 2. I don't remember the gearbox being that smooth on the OEM fluid. When it comes to transfer case definately use diaqueen.
MZ313376 from mitsubishiparts.net
I did research all the available GL-4 fluids before I put the BGII into my gearbox and decided it was fine for my application. I don't race my car and I change the gearbox fluid every 15Kmi. If I was racing and had mods than I would look into the "Shep formula" of mixing BGII with heavier MT-90. But I drive my Evo every day and in the Winter a really heavy mixture would be harmful to my synchros until the fluid finally warmed up. I look for shavings everytime I do my change and have not found anything abnormal.
https://www.amsoil.com/storefront/mtg.aspx
Just my .02...but I would never run that BG ever again. The BG brokedown after 10k - and whats the weight of it? (hint: its unknown).
Thread on a lot of different fluids:
https://www.evolutionm.net/forums/sh...ghlight=amsoil
I have been running Amsoil trans fluid (correct weight for our cars also) for 12k or so. I lik it way better than the BG stuff.
Are you using Amsoil gear lube for your tc and rear diff?
i pulled my BG out 500 miles ago after about 7500 miles... it looked like it did when i put it in there.... feels good as well. Now i have a mixture of mt90 and mtl in there, feels good also. May try the Shep cocktail next
