HELP!!! with trunk!
its freaking easy, in fact i just put my cf trunk on today...once again its really simple to take it off, putting it back on is the hard part, im not gonna try to explain it would take too long
yes he means tension bars
if you plan on running a carbon trunk you will need to eliminate one bar otherwise it will put hella stress on the trunk
I went from an evo ix trunk with a wing to an evo ix rs trunk and I have some tension on the trunk but one bar won't open it because it weighs too much...just an fyi
YOU DEFINITELY NEED A SECOND SET OF HANDS!!!!!!
def need more than one person for the install at least, you can take off the old trunk by yourself, i removed mine by myself, the tension bars can be a pain in the *** but ive done this more than once so it was pretty easy. putting on the new trunk takes some time because of alignment and all that fun ****, you might need washers or metal shims for the metal piece that is bolted down in the trunk my latch didnt quite lock so thats what i had to do(ACE hardware has everything you need )
