Sparco or Autopower?
Old Oct 9, 2007, 09:48 AM
V8eatr's Avatar
Im debating between ordering the Sparco Harness bar w/ 3 point Sparco harness belts or getting the Autopower 4-point street sport roll bar. Which would you guys suggest me getting?
Old Oct 9, 2007, 10:05 AM
lexat20's Avatar
Autopower has more function. Harness bar most will say is dangerous. The rollbar would serve its purpose in a worst case scenario.
Old Oct 9, 2007, 10:13 AM
CaymanEvo3's Avatar
Get the Auto power.
Old Oct 9, 2007, 10:35 AM
V8eatr's Avatar
thanks
Old Oct 9, 2007, 10:39 AM
V8eatr's Avatar
Does it restrict seat movement a lot or should i be alright, im 6' tall?
Old Oct 9, 2007, 11:34 AM
nukblazi's Avatar
The autopower does not restrict seat movement fore and aft. If you drive "laid back", either will get in the way. Neither are safe for rear seat passengers.
The harness bar is ok for autocross IMO. However it does nothing in the case of a roll or high speed side impact, and could infact cause additional injuries.
Here is the important part;
If you are doing any kind of motorsport, or intend to use the harness, you need a 5 or 6 point.
Why? Never thought you'd ask. With a 4 point, tightening the shoulder straps will lift the lap belt off your lap. In the case of an impact, you will submarine under the belts. Most sanctioning bodies will not let you run a 4-point, as the OEM 3-point is safer.
If it's for show, why bother? You lose safe use of the rear seats. If you need it, Autopower and a 6 point. (that's what I have)
Old Oct 9, 2007, 12:07 PM
Robevo RS's Avatar
there is a 4 point harness with submarine protection out there.
its certefied too.
i use the cheapest 5 point harness/g-force/ because for regulation you need to change them every 2 year. So i don't want to spend 300-400 for evey two year for harness.
if you get a takata that spending can be as much as $800 a pair...
Old Oct 9, 2007, 12:11 PM
EvoIXMR's Avatar
autopower is what I will do as its somewhat reversible.
I want to see if its fully approved for SCCA, NASA use etc....
Old Oct 9, 2007, 02:07 PM
tnhockey's Avatar
autopower ftw
Old Oct 9, 2007, 02:35 PM
Doowop's Avatar
autopower, that is what I am going to do.
FYI for the harnesses, if it is a FIA rated it is 5 years and not 2 at least in the SCCA.
Old Oct 9, 2007, 02:42 PM
AutobonEvo's Avatar
Autopower i have one and love it.
Old Oct 9, 2007, 03:03 PM
LilRico's Avatar
Any pics of the Autopower in their car... I wanna see how much room it takes up... Thanks..
Old Oct 9, 2007, 03:12 PM
SICK9's Avatar
+1 post pics of autopower plz..
tia
Old Oct 9, 2007, 04:50 PM
letMeIn's Avatar
my Autopower should arrive this week. Recaro PolePosition and 5 point harness in 2 weeks... can't wait
Old Oct 9, 2007, 10:22 PM
EiVxO's Avatar
there is no cutting or highly modifying interior for cage to fit right?
Quick Reply: Sparco or Autopower?
