Immediatly blowing 7.5 fuse in engine bay when i replace it. Help!
#31
Since you mentioned it happened after a hard rain fall...just for giggles, take a gander by your dead pedal and see if there are any wires that show any flash rust/corrosion. This has been happening a lot to people when their grommet comes loose and water from the wheel well drips down into the cabin.
#33
start at basics...since its blowing out your pass lights and ish...my driver sides blew out..found bulb shorted corroded in socket in side of rear quarter panel..with a good fuse in if you can check and see what all is working..etc..make sure all bulbs work even the tiny marker bulbs (162's or 164's i forget) mine threw me for a loop for a couple days til i get it not to pop and saw the bulb out..good luck my friend
Darkn3s
Nov 20, 2013 07:49 AM
mksevo
Evo X How Tos / Installations
65
Jul 20, 2013 10:05 AM
SimpleAznMan
Lancer Troubleshooting
10
May 14, 2013 08:14 PM
