how often do you engine brake?
i just wanna know if its ok to engine brake once in a while after going at a high speed? i use the heel-toe technique..
Yes, you'll be fine. I heel-and-toe all the time when taking cruises through twisty roads or even just around town for fun (not at very high revs for the latter). Just make sure your technique is good and you're not shocking the engine by popping out the clutch when it's not rev-matched.
