Front end noises
Old Oct 25, 2007 | 06:16 AM
xsolowx's Avatar
Front end noises
Anyone have any ideas on this? 2003 evolution viii kind of a clunking noise on every little bump. Sometimes it goes away for a while, but eventually comes back.
Old Oct 25, 2007 | 06:24 AM
whoang40's Avatar
you install a downpipe or TB exhaust? Mine did that after downpipe install. Hopefully it's not one of your struts going out, suspension mods? You'll have to let us know what mods you have or just done recently.
Old Oct 25, 2007 | 06:27 AM
deadbeatrec's Avatar
im having this issue with my rear suspension. just put in new megan coilovers and i have a feeling my bearings are going bad. it sounds like something is loose.= but i have checked and checked again to make sure everything is tight
Old Oct 25, 2007 | 06:33 AM
Hendrix's Avatar
About a year ago I had a clunking noise coming from the front driver's side. It ended up being the spring rubbing against itself when it compressed. I put a small piece of rubber hose on the end of the spring and never heard it again.
Old Oct 25, 2007 | 06:58 AM
w8lifter21's Avatar
Pics of where you put the piece of rubber? Mine is doing this REAL bad
Old Oct 25, 2007 | 08:15 AM
xsolowx's Avatar
Not sure yet if it has suspension mods..i just bought it a couple of weeks ago and it just started making this noise. I was planning on pulling the wheels of this weekend and taking a look. I know it does have custom exhaust and spearco intercooler. It has 29,000 miles on it
Old Oct 25, 2007 | 08:23 AM
well as for me, i just went into the p-lot at my work, jacked up my car and tried moveing the wheel as if there was bearing play. NOTHING!! wtf?
Old Oct 25, 2007 | 08:30 AM
distant_02's Avatar
I have similar noise from the rear...with my BC coilovers. I've always thought it was normal cause I had the same noises with my previous car on Tein coilovers.
Old Oct 25, 2007 | 08:31 AM
ThinkEvo2007's Avatar
do u have hard pipes for your intercooler?. if so make sure there secured. i had a little problem with that
Old Oct 25, 2007 | 09:01 AM
well about 1 hour ago i jacked up my car in my works p-lot and was trying to move the wheel as if the bearings were shot. nothing. no play at all.
Old Oct 25, 2007 | 09:48 AM
distant_02's Avatar
The extent of what i've checked is just making sure everything was torqued to spec.
Old Oct 25, 2007 | 09:52 AM
mac74's Avatar
Mitsu is known for lower control arms and ball joints. The nosie is the same you are going through. I had a 97 gst with the same problem would clunk sometimes and sometimes not. It was the lower control arm. I would also check the strut mounts if they are getting dry and going they will also make the same noise..
Old Oct 25, 2007 | 10:00 AM
tvbf1's Avatar
Do you have the under tray on?
There's like a piece of metal that's riveted onto the car in the center. The under tray is then riveted onto that piece. If the under tray is gone and that piece is there, it'll make a clinking or rattling sound during 1st gear accel or at low speed bumps and stuff like that.
Old Oct 25, 2007 | 10:14 AM
evolution7jm's Avatar
noise
evos are just noisy if you try to elimitnae all the noises especially clunking noises in the evo you will never get to drive it. i have tryed several things to stop the clunking noises that the evo makes in several evos it always makes noise. just enjoy your car
Old Oct 26, 2007 | 07:02 AM
Hendrix's Avatar
I don't have any pics, I just slid about 3-4 inches of rubber tube on the end of the spring. Some aftermarket springs come that way, that's where I got the idea.
