Where can i get touch up paint (spray can)?
Old Oct 28, 2007 | 09:31 PM
TwStDeVo's Avatar
i have an apex silver evo and was wondering where i can get matching touch up paint that comes in a spray can? i had my fenders rolled by robi a while back and he gave me a website where i could get some, but i lost it and have not been able to get a hold of him. definitely appreciate the help!
Old Oct 28, 2007 | 09:39 PM
SICK9's Avatar
I've used paint from here before.
http://www.automotivetouchup.com/
or you could just google auto touch up paint.
Old Oct 29, 2007 | 11:16 AM
barneyb's Avatar
Try Walmart. I got Phoenix Red (Rally Red) in a spray can there.
Old Oct 29, 2007 | 11:19 AM
TwStDeVo's Avatar
anyone know a paint that i can get from either walmart or pepboys that matches apex silver?
Old Oct 29, 2007 | 01:57 PM
SLVROZ_03's Avatar
www.paintscratch.com
Old Oct 29, 2007 | 02:51 PM
LoCo4's Avatar
Originally Posted by SLVROZ_03
X2 Love their paint. Match is almost perfect!
Old Oct 29, 2007 | 04:45 PM
TempeRacerGuy's Avatar
just go to your local auto body supply shop, ask them, many can put PPG paint into a rattle can that is a near direct match. Typically it's $15-$20 per can.
Old Oct 29, 2007 | 05:05 PM
TwStDeVo's Avatar
^^ i will try that, i got a cwest front bumper and got to close to a parking bump and now got like a 2 inch spot near the bottom lip where the paint came off, no cracks or anything. so im thinking about just taping that section off and using the spray can paint (cant decide whether one or two coats) and then a coat or two the the clear coat (spray can). what do you guys think?
Old Oct 29, 2007 | 05:15 PM
Ultimate CC's Avatar
its its cracking its likely to just crack even more if you spray paint it...i would just bring it to a shop...
Old Oct 29, 2007 | 05:36 PM
The reason it peeled off is because whoever painted it first didn't use a good adhesion promoter or a flex-additive in the clear coat.
If it's flaking off with a flex, it's just going to get worse. I would not suggest a spray can touch-up over a bumper.
Bring it to a shop, have them strip it and re-do it this time the proper way.
Sorry dude.
Old Oct 29, 2007 | 05:42 PM
Drew1020's Avatar
i tryed touchin up some of my chips and looks pretty good cept for the spot on my door. went to a local body shop and they gave me a lil bottle thing of touch up paint
Old Oct 29, 2007 | 07:09 PM
BlueDemon's Avatar
^+1 Go to a body shop. They can give you 10-20 oz of touch-up paint in a bottle for cheap. That's what I have and make sure you store it on room temperature so it last longer.
Old Oct 29, 2007 | 09:50 PM
TwStDeVo's Avatar
i will take a pic tomorrow and would appreciate it if you guys can guide me the proper way, i want to fix it so i can get a custom clear vinyl on there.
Old Oct 30, 2007 | 03:58 PM
TwStDeVo's Avatar
here is the pic of what im trying to fix, appreciate the help guys!
http://public.fotki.com/twstdevo/evo/1030071536.html
Old Oct 30, 2007 | 04:29 PM
Hmm, that pic is pretty blurry. You want to look at the edges of where the paint started to come off. If it looks like the impact itself is what rubbed off the paint, then you just need to have it touched up at a body shop. If however the impact pulled paint from past the impact point, then the paint doesn't have a flex-additive in it, and doesn't adhere to the bumper well. If this is the case, it needs to be stripped and re-done.
Think of it this way... If you have a flex additive, it's like putting a rubber coating on a rubber ball, when something impacts it, the ball and the coating both flex, so the paint is only damaged where the immediate impact is.
If you don't have a flex additive, it's like putting a hard candy coating on a rubber ball. When something squeezes the ball, it cracks through the paint, then pulls the ball away from the paint inward. as the paint can't support itself the paint flakes away from around the impact point. Sometimes if the paint adheres well to the bumper, but does not have a flex additive, it creates a spiderweb cracking effect around the impact point.
In either case, the correct fix is to take it to a body shop. Touch up paints don't have flex additives in it.
wickedevos
Sep 30, 2021 03:23 PM
Ralli04
Nov 29, 2006 08:53 PM
hkfeet
Jul 25, 2006 10:04 PM
herbal77
Feb 1, 2005 09:50 PM
sdhotwn
Lancer How Tos / Installations
Mar 25, 2004 09:46 AM
