No 02 Dump in the market?
#183
What would be nice, is if a company could fab something up on the actual downpipe. This is what I was running when I had my 90 7MGTE Supra. Sounds badass @ WOT.
"This specially designed full 3" downpipe utilizes a seperate pipe for the wastegate exhaust that vents to the atmosphere, making for less turbulence and higher flow for more power gains. Dyno results have shown gains of 29 whp over a standard 3 inch downpipe setup."
#189
#191
You know what I just thought of.... Just like the electric downpipes, you can have open downpipe at the flip of a switch. They should make o2 eliminating downpipes with a dump tube like that with one of the butterfly valves on it, so if you're in the mood to scare pedestrians, flip the switch! Only probably would be clearance.
#192
Here is a quick drawing
So what company wants to fab one of these with an electronitc cut out of the dump pipe? I'm only asking for 15% of the profit
I know there is a compnay out there that makes the top version, which could be easily modded for VTA.
#193
who makes this!!!
