changed oil and still dirty?
Old Oct 31, 2007, 12:01 PM
nightferret's Avatar
i changed my oil yesterday and the oil is still a bit dirty. not horrible but it didn't look like as clean as it should of been. is it possible that there is still some oil in the oil cooler (don't know the exact name for it) i dont understand how i didnt get it all out? any suggestions or tips? or perhaps im just an idiot. =(
Old Oct 31, 2007, 12:06 PM
mdsevo06's Avatar
Do an Oil Analysis to see what's going on with your internals. Blackstone-labs.com is great to deal with and reasonable.
Old Oct 31, 2007, 01:08 PM
KFC-AWD's Avatar
when u change the oil, u arent getting it ALL out, there is still some in the oil cooler, etc.
Old Oct 31, 2007, 01:10 PM
mifesto's Avatar
yes there is always like half a quart in the oil cooler. either way dont stress over this.
Old Oct 31, 2007, 01:25 PM
Registered User
brandonl's Avatar
I get the same thing, no mechanical issues at all here.
Old Oct 31, 2007, 01:36 PM
alright im glad to hear that. is there any trick to get it all out or is it just something ive got to deal with basically?
Old Oct 31, 2007, 01:59 PM
Pr3z's Avatar
Change it, drive around the block, change again, and your oil will be crystal clear if thats important to you and have 100 bux to blow on oil.
Old Oct 31, 2007, 02:30 PM
4TUN8's Avatar
+1
Old Oct 31, 2007, 03:26 PM
Redline-Z's Avatar
your oil should look colored, that means it is doing its job.
Old Oct 31, 2007, 03:30 PM
fryedchikin's Avatar
+1
Old Oct 31, 2007, 03:33 PM
h.funk's Avatar
I do a little flush. But your always gonna have some residual
Old Oct 31, 2007, 07:38 PM
Klei14's Avatar
They make oil just for doing a flush, but I dont know how good it is for the motor. But blackstone does good work.
Old Oct 31, 2007, 07:44 PM
motdongsan85's Avatar
they charge 39.99 for flush at local Giffy lube... they said dirty oil will cause damage and eventually cause knocking?? should i believe this?
Old Oct 31, 2007, 08:08 PM
DSMorBUST's Avatar
i certainly would NOT trust a jiffy lube or any other place to do an oil change.... lol
Old Oct 31, 2007, 08:24 PM
amprowler's Avatar
Did you take off your oil filler cap and dip stick before you drained your oil?? That might also be a cause of really dirty oil after an oil change.
Quick Reply: changed oil and still dirty?
