JDM Pie Cut manifold
You take a straight section of pipe, and cut multiple wedges or "pie cuts" out of it, and then weld it back together. It's popular as you can make custom bends on the cheap.
There is no bending involved. I know what I am talking about just looking for a pic
There are, however, a couple American companies that do something close to what you are talking about...
Full-Race:
AMS:
the reason people did this is not for performance, as it is NOT as good as a smooth bent tube
however, the reason it can be beneficial is that you can make a tighter bend and it can be more complex...if you tried to bend a tube to some of the tight angles pie cuts can accomplish the tubing would "kink" (for lack of a better word)
also, one of the pics above shows titanium tubing, which is not a metal that bends easily due to how brittle it can be...so in that instance it would almost be necessary
