Oil Temp Sender Question
I just removed the factory gauges (boost, oil temp, volt), and I've figured out what all of the wires are except for the oil temp sender. There is a black wire with a white line, and a white wire. I'm asking because I'm trying to install autometer ultralites, and the oil temp gauge that I have has only one sender connection, along with a ground and ignition. Can anyone tell me what these wires are, and if anyone knows if and how to connect to my new gauge. Thanks in advance.
Do you have a voltmeter? Just check and see what sends what voltage (12V) and when (Ignition on, low pressure, high pressure). It's kind of confusing, but once you see how to do it, you'll be much better off in the future with the electrical components of the vehicle.
Ground is black, igntion will be the power one and the other one goes to the sender itself.
Ignition wire goes to anything that has on off power. Like your stereo, dome light ignition (which from what I heard is in the steering column and a thick white wire) I have mine to my stereo power wire so when I shut my stereo off the gauges shut off.
I know what the wires are on the gauges, and I reused the connections that were already on the car for ignition and ground. The problem is that the new gauge has one wire for the sender, whereas the factory installed gauge and oil temp sender has two wires (black w/ white stripe, and solid white). I’m trying to figure out whether the factory temp sender is compatible, and if so, what necessary connections i have to make to ensure it works properly.
And thanks Thegame, you’re the second person that has told me to do that so looks like I have some learning to do!
White with stripe- signal
white- grounded to chassis
black- ground: light
yellow- 12V: light
red- 12V igntion
This is for a Stewart Warner oil temp gauge install with the stock oil temp wiring.
yellow- 12V: light
red- 12V igntion
So after grounding the white wire, and using the black w/white stripe for signal I finally got the gauge to give me a reading. I took it around the town for about 4 or so miles, mind you my car had already been warm from driving home from work. The gauge wouldn't come past 100f. So I'll leave it installed for a while and see what i find out.
Thanks LoCo4 for the prompt help.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Thanks LoCo4 for the prompt help.![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
Yeah its been in the 20s here, but I would think the oil temp would break 100. But thats why I've decided to leave it for a while and see if we get an unusually warm day.
well today we have some high weather, close to 50, so im gonna be driving around a bit after work to see if i can get this gauge to give me something
Jp7
Jul 30, 2017 05:29 PM
llDemonll
Pacific Northwest
11
May 22, 2012 01:35 PM
nofear
12
Dec 21, 2007 01:09 PM
CombatCQB
Oct 28, 2003 05:17 PM
