Innovative lc-1 problems
Old Nov 28, 2007, 11:18 PM
Jspec EVO VIII's Avatar
So today i was trying to connect the cable to my laptop w/a serial to usb adapter and my laptop couldn't recognize it. Did this all before i connected it to the lc-1. I tried my tactix cable to see if something was up w/the usb ports but it read my ecu just fine. Any clues? The adapter i got was one from Bestbuy since i read on here the Radioshack one isn't too great. I'm stumped.
Old Nov 28, 2007, 11:52 PM
Dapper Dan's Avatar
it should have came with a disk.... did you load it up first?
Old Nov 29, 2007, 02:14 AM
Yup, still won't recognize the cable. The disk had the logworks program in it.
Old Nov 29, 2007, 05:12 AM
Dapper Dan's Avatar
mayve that cable just wont work..i ordered mine online. I had a radioshack one that didnt work...
Old Nov 29, 2007, 05:24 AM
TouringBubble's Avatar
Did you install the drivers for the serial > USB adapter? You need both .. the drivers for the LC-1 and the drivers for the adapter you purchased at Best Buy.
Old Nov 29, 2007, 05:47 AM
The cable from Bestbuy didn't come w/a disc. Was it supposed to?
Old Nov 29, 2007, 05:55 AM
nothere's Avatar
the lc-1 may need to be connected to the serial cable before you try to connect?
Old Nov 29, 2007, 06:11 AM
travman's Avatar
Yes it does.......
If its the dynex cable from best buy the disk is in between the cardboard in the package. You have to pull it apart, I thought the same thing but then pulled the package completely apart and found it.
Or you can just go to the dynex website and DL the driver...... but if you bought it brand new from best buy you have the disk.
Old Nov 29, 2007, 07:58 AM
Evol.ved's Avatar
http://www.newegg.com/Product/Produc...rs232%2bpcmcia
Get this and be done with it. Serial to USB adapters are always a pita
Old Nov 29, 2007, 08:02 AM
cfdfireman1's Avatar
yes
you may be able to get drivers from the manufactures website.
Old Nov 29, 2007, 02:50 PM
Didn't find any disc, but i found a link to dl from the dynex website. Going to try it out later tonight after i get some other things done, be back tonight with an update.
Old Nov 29, 2007, 03:13 PM
CrackerJackToy's Avatar
The best buy cable sucks. The radio shack cable works perfect.
Old Nov 29, 2007, 03:38 PM
grenade's Avatar
Im sure it depends on the Manufactur, as Mine works flawlessley
Old Jan 18, 2008, 01:59 AM
Bump. Found the disc, got everything loaded up. I kept getting this error when i tried to connect the com port here's what it said:
No real time data detected. Check serial port and connection. Note, you must use 'Download lm-1 log from the file menu' instead of a real time operation in 9v battery mode
It connected once, after that i tried it again, and got the same error. I'm stumped. Any suggestions on brands? I'm thinking on ordering the one from newegg that Evol.ved mentioned. Any help?
Old Jan 18, 2008, 02:34 AM
Dapper Dan's Avatar
maybe try to make sure the terminator plug is in the end of the lc-1 really tight..... double check all of your connections. Also try switching the usb cable to a different spot on your laptop
Quick Reply: Innovative lc-1 problems
