Clutch time...boooo
Clutch time...boooo
time for a clutch on my ix......to much beatin on the evo i guess lately...im goin with the act 2900 with street disc but im wondering if i should do a flywheel to or no...if so give me some sugestions of what kind...it will be on a ix with about 380-400 whp when its put in....thanks guys
Registered User
Yeah, I'm dreading the day that I need to replace the OEM clutch in my 05 evo. It has 21K miles on it now. I don't launch it, that's why it has lasted this long.
Anyway, back to your question, I would replace both clutch and flywheel. I'm sure if you search enough, there are vendors having holiday deals on a combo. If not, make sure the flywheel is resurfaced and the clutch is done by someone who knows what they are doing.
Jason
Jason
Unless the clutch pedal pulsates or the clutch shudders all you need to do is go over the flywheel with a roloc disk to clean it up a bit. Takes like 30 seconds and you don't have to take it off.
No do not get a ACT clutch we just had a thread about theses clutchs for evo's and it ended getting cleaned up because some of us went a lil over board.
I had this same clutch for 3000 miles it sucked so bad it wasnt even funny it was adjusted countless times. But it still locked out a high RPM.
Well im on my 2nd stocker and right now im running a GT35r @26psi with out problems at all. The only draw back is i cant launch it or good bye clutch! Just waiting on putting in my cusco twin or my ATS tripple carbon.
