OEM paint + good price???
car manufacturers almost always outsource their paint from some other paint manufacturer. give the service parts guys a call. i'm sure theyll tell you who provides the o.e stuff.
Look for an auto body supply store, they almost always mix paint in house. All you have to do is choose the system ( Sikens/ Du Pont.....ect.) and is best to stay with the same system for all the products. Only white and black can be shot right out of the can with no tinting..almost all other colors require tweeks to get a perfect match. And if you have never painted a car..then do not, it is not DIY at all.
I just got back from my local paint supply and the range is $40 to $60 per quart for Blue Effect (depending on brand). I would bet BBY is cheaper since its not metallic. It takes 3 quarts with a 1:1 mix ratio netting 1 1/2 gallons. This would be enough to do door sills, firewall, interior trim pieces and some engine dress up.
A gallon of clear coat is $85 with activator and I have a ton of powders to add to it for a more custom look if want to go that route?? With your help we could knock it out in a weekend.
Take it to a reputable paint shop. They should be able to match any color. How it works is they look up the manufacturers paint code and their paint supplier (whether its PPG, dupont or whoever) will give them a formula. They will mix the formula and then fine tune it to match perfect. BTW, the durability of the paint job is all in the clear, not the base coat.
Oh, my dad has owned a body shop for 25 years so I've been around the business for a while
Are you wanting to paint it yourself or something? It's going to look much worse if you do.
regardless of your intetions with that post, your information is incorrect. you wouldn't build a house on a ****ty foundation, why would you paint on one? the durability of a paint job has way more to do with several factors, not JUST the clearcoat. didnt your daddy teach you anything?
there are two types of bond, chemical and mechanical. mechanical bond is where the surface has abrasions or pockets to attach the material to.
chemical bond is where the material and surface react to each other, and mesh together by melting or re-liquifying and then drying. but you already knew that right?
so if the basecoat is crap, then it wont matter with the clear, because there will only be crap to stick to.
please dont post your garbage here. these people are truly looking for good information and you have provided nothing but misleading nonsense. if you want to promote your daddys shop, do it with local people. the question was where to get oem paint at a good price. i didnt see anywhere he was asking for soemone to make assumptions.
