do I NEED a boost controller?
lol.. you don't NEED a boost controller... it is just a recommendation for extra horsepower .. the factory boost on an evo is 20.14lbs of boost.. you can get a boost controller and run 21-23 and you get roughly 10 extra hp per each pound of boost..
usually a basic bolt on car gets.. intake, mbc, turbo back exhaust, fuel pump, and flash
How do you modify the restrictor pills??I was about to buy a MBC,but,if i can turn it up without buying one..That would be better..Anywhere that i can look to find the info??Justin
but it usually will hold 18-16psi depending on the weather.
one thing i noticed once i put my MBC in, i now have hardly any boost spike. it hits 21psi and holds it all the way up to redline
Remove the brass restrictor pill near the turbo. Fill it with solder (easy). Purchase a #65 drill bit from the hardware store and drill a hole in the solder (easy). Replace brass pill. Instant 25lbs of boost that is controlled via WDC in the ECU. If you look at my dyno chart you will see it still drops off up top but they all do that. With a few tweaks I was able to remove the wave and hold boost better than with an MBC.
The restrictor pill mod works but spike is usually more common which can be a pain. Some people claim they don't have any spike/creep issues while others claim its the devil but if you don't feel comfortable modding your BCS MBC's are pretty inexpensive and pretty effective.
When I had my turbo miata, i gained 30-35whp and 40wtq from turning the boost up from 7 lbs to 10 lbs.
One day I was cruising around town. I noticed my car was ***** slow. BIG TIME. I couldnt figure out what was going on. I kept getting on it & it just didnt feel right. The *** end was actually keeping traction...which was weird for the car. I then finally decided to look over at my air vent where it held my 2 1/16ths boost gauge, and noticed it was only on 7 lbs. I was like 'ohhhhhhhh yeah!' I totally forgot that I made a 'gas saving map'. Flipped a switch to my regular map... hit the gas... and weeee goes the back end sliding around like a go-kart at 40mph. Sick car!
Technically more boost is still good even out of the efficiency range as long as there is sufficient cooling.
I remember back in the day someone ran a few tests from 17 psi, 20 psi and 23 psi on the stock T-25 2G dsm turbo and each time it increase slightly. If I recall the jump from 17 to 20 increased 18-20hp and the jump from 20 to 23 only produced an extra 8-10.
If you've ever seen a t25 it's ungodly small and anything over 18 psi is out of it's range.
1 Post
a MBC will make it easy for those days of tuning where a simple screw up or down will adjust your boost. yes you can always use the stock solenoid but the MBC will hold it a little better up top././
