Rear O2 sensor "not ready" state
Old Dec 23, 2007, 02:05 PM
EVO316's Avatar
ok so I should drive it more for several cycles.
so the mechanical fix on the buschur exhaust won't return a "not ready" signal everytime. from my research an electrical fix will give a "not ready" every time, the mechanical fix should not.
Old Dec 23, 2007, 03:50 PM
EVO316's Avatar
bump, any other helpful advice.....
Old Dec 23, 2007, 03:58 PM
geevolution's Avatar
this is strange, I just recently got inspected, I had a dead rear o2 but it still indicated that it was in ready state. Just cleared it drove it for 20 miles to trip it, then passed with no problems whatsoever. btw I also have a test pipe
Old Dec 23, 2007, 06:35 PM
EVO316's Avatar
night bump, any other input???
Old Dec 23, 2007, 07:45 PM
EVO316's Avatar
another bump, really needing advice so that i can pass state inspection.
Old Dec 23, 2007, 07:55 PM
have you tried throwing on the stock cat, or changing the sensor? also somebody above stated that you should contact jestr, have you done that yet?
Old Dec 23, 2007, 08:02 PM
EVO316's Avatar
sent him a pm...waiting for reply.
Old Dec 23, 2007, 08:21 PM
nothere's Avatar
I can tell you what will work, just passed obd2 here in my state.
hiflow cat with o2 sensor extender.
it would throw a cel without the extender.
if you drive around for an hour or two that should enable the tests within the ecu.
can't help you with an answer if you are trying the test with a test pipe
as a last resort my state allows a "pass" if you can show you have spent $150 towards fixing the problem by a certified emissions person. Of course he might frown on a test pipe.
Old Dec 24, 2007, 07:51 AM
EVO316's Avatar
I am going to drive the car through a whole tank of gas, then go to auto zone to get it scanned if "ready" i will head straight to inspection.
thanks for the input fellas.
Wapoosh
Oct 1, 2016 02:34 PM
kalendrinn
Dec 14, 2015 10:40 PM
sabastian458
43
Nov 2, 2015 01:35 PM
commandwolf
Oct 26, 2009 07:53 AM
BluesunsXIV
Jun 27, 2009 06:34 AM
Quick Reply: Rear O2 sensor "not ready" state
