Got license plate ticket!
#31
When I use to have an MR2... I zip tie my plate in front of the radiator. I think you can probably zip tie it to the front grill of your evo instead of drilling hole or glue or the 3M double sided tape. The only thing is that you will not get as much air to the intercooler
#32
I have mine zip tied to the mesh on the driver side of the intercoller and the other side i duno i think its just kinda bent in there. It is not covering the intercooler no more then 1/4 inch. So basically not covering it at all.
#33
California Vehicle Code
Division 12
Chapter 4
Material Obstructing or Reducing Driver’s View
26708. (a) (1) No person shall drive any motor vehicle
with any object or material placed, displayed, installed,
affixed, or applied upon the windshield or side or rear
windows.
(2) No person shall drive any motor vehicle with any
object or material placed, displayed, installed, affixed, or
applied in or upon the vehicle which obstructs or reduces the
driver’s clear view through the windshield or side windows.
(3) This subdivision applies to a person driving a motor
vehicle with the driver’s clear vision through the windshield,
or side or rear windows, obstructed by snow or ice.
(b) This section does not apply to any of the following:
(1) Rearview mirrors.
(2) Adjustable nontransparent sunvisors which are
mounted forward of the side windows and are not attached to
the glass.
(3) Signs, stickers, or other materials which are displayed
in a 7-inch square in the lower corner of the windshield
farthest removed from the driver, signs, stickers, or other
materials which are displayed in a 7-inch square in the lower
corner of the rear window farthest removed from the driver,
or signs, stickers, or other materials which are displayed in a
5-inch square in the lower corner of the windshield nearest
the driver.
(4) Side windows which are to the rear of the driver.
(5) Direction, destination, or termini signs upon a
passenger common carrier motor vehicle or a schoolbus, if
those signs do not interfere with the driver’s clear view of
approaching traffic.
(6) Rear window wiper motor.
(7) Rear trunk lid handle or hinges.
(8) The rear window or windows, when the motor vehicle
is equipped with outside mirrors on both the left- and righthand
sides of the vehicle that are so located as to reflect to the
driver a view of the highway through each mirror for a
distance of at least 200 feet to the rear of the vehicle.
(9) A clear, transparent lens affixed to the side window
opposite the driver on a vehicle greater than 80 inches in
width and which occupies an area not exceeding 50 square
inches of the lowest corner toward the rear of that window
and which provides the driver with a wide-angle view
through the lens.
(10) Sun screening devices meeting the requirements of
Section 26708.2 installed on the side windows on either side
of the vehicle’s front seat, if the driver or a passenger in the
front seat has in his or her possession a letter or other
document signed by a licensed physician and surgeon
certifying that the person must be shaded from the sun due
to a medical condition, or has in his or her possession a letter
or other document signed by a licensed optometrist certifying
that the person must be shaded from the sun due to a visual
condition. The devices authorized by this paragraph shall not
be used during darkness.
(11) An electronic communication device affixed to the
center uppermost portion of the interior of a windshield
within an area that is not greater than 5 inches square, if the
device provides either of the following:
(A) The capability for enforcement facilities of the
Department of the California Highway Patrol to
communicate with a vehicle equipped with the device.
(B) The capability for electronic toll and traffic
management on public or private roads or facilities.
(c) Notwithstanding subdivision (a), transparent material
may be installed, affixed, or applied to the topmost portion of
the windshield if the following conditions apply:
(1) The bottom edge of the material is at least 29 inches
above the undepressed driver’s seat when measured from a
point 5 inches in front of the bottom of the backrest with the
driver’s seat in its rearmost and lowermost position with the
vehicle on a level surface.
(2) The material is not red or amber in color.
(3) There is no opaque lettering on the material and any
other lettering does not affect primary colors or distort vision
through the windshield.
(4) The material does not reflect sunlight or headlight
glare into the eyes of occupants of oncoming or following
vehicles to any greater extent than the windshield without
the material.
(d) Notwithstanding subdivision (a), clear, colorless, and
transparent material may be installed, affixed, or applied to
the front side windows, located to the immediate left and
right of the front seat if the following conditions are met:
(1) The material has a minimum visible light
transmittance of 88 percent.
(2) The window glazing with the material applied meets
all requirements of Federal Motor Vehicle Safety Standard
No. 205 (49 C.F.R. 571.205), including the specified minimum
light transmittance of 70 percent and the abrasion resistance
of AS-14 glazing, as specified in that federal standard.
(3) The material is designed and manufactured to
enhance the ability of the existing window glass to block the
sun’s harmful ultraviolet A rays.
(4) The driver has in his or her possession, or within the
vehicle, a certificate signed by the installing company
certifying that the windows with the material installed meet
the requirements of this subdivision and identifies the
installing company and the material’s manufacturer by full
name and street address, or, if the material was installed by
the vehicle owner, a certificate signed by the material’s
manufacturer certifying that the windows with the material
installed according to manufacturer’s instructions meets the
requirements of this subdivision and identifies the material’s
manufacturer by full name and street address.
(5) If the material described in this subdivision tears or
bubbles, or is otherwise worn to prohibit clear vision, it shall
be removed or replaced.
#35
I wouldn't consider it them stealing as much as I'd consider it you donating money to them. Or are the laws not published where you're at?
Also, yes speeding 5-10 over the speedlimit is uh well speeding. Do 10 over in a 20 around here and you can get pegged for being reckless.
Pinky - the cost is actually $130.00, good chunk of money they steal from you if you just dont want to do it. I did that last time I got a no plate ticket about 6 months ago and the crazy thing is, the next day I got this no plate ticket which I extended, now I have to take care of it somehow...
evo@24psi - On my previous IS, I've done this a couple times, just crazy glued (or rubber cemented) screws that had the ends cutoff on the actual two holes, and then used double sided tape to attach it to the front bumper, I just wanted to see if there was an easier way before I do it again.
glgz - and to whoever else that just wants to put it on and forget about it, this is what I have come up with.
a) I have been pulled over quite a few times for speeding (going just 5-10 mph over the limit is speeding to some a hole pigs) and they just wrote me off with a fixit ticket for not having a front plate versus a real speeding ticket so not having a front plate may actually save you from getting a real ticket sometimes unless the pig is a REAL BIG A HOLE and gives you a ticket for no plate AND speeding, thats happenned to me once.
b) More and more camera enforced intersections are coming up by the day, literally on almost every intersection, there are cameras, so you have no plates on, you dont need to worry if you pass a late yellow light and the camera flashes and its your car in the middle of the intersection...
Therefore no way, no plates.
I thought of the zip tie idea but it wont pass, they say, it needs to be screwed safely to your bumper, bastards.
#36
#37
Here's a really good option I found for you...
https://www.evolutionm.net/forums/sh...ghlight=bumper
#38
I feel your pain. After a similar run in with Johnny Law I decided to use magnets to secure my plate to my front bumper. Well it's been over 6 months, and I've been through blizzards and monsoons...never fallen off once. Also tested up to 120mph (closed course) without worry. Best part is I can pull it right off without effort.
#39
Take a pic of the car w the liscence plate on....
Drive a different car or get dropped off at court....
show the judge that you have the plate on
hope not to get pulled over again!
#44
Here in Virginia 2 plates are required, however, I haven't had a chance to follow up with the DMV yet but I heard from somewhere if you register your car as a sports car only 1 plate is required.
Has anyone else heard this?
#45
This is what some people have done...... not saying to do so. but..
Call DMV and report your front license plate stolen. When you get pulled over inform them you have already called up and done so.. If you get a ticket the call and it being on file will be your ticket out.
shame on you trying to cheat the system like that, what about just placing it on the windshield from the inside?
