Gas pedal removal
Gas pedal removal
All right, so I searched and couldn't find the answer I'm looking for. If you know the thread I can find the info, then point me in that direction and delete this thread.
Here is the problem, I have an IX MR with the Mitsubishi Racing Pedals as seen in the following link.
http://www.lancershop.com/customer/p...&cat=14&page=2
I want to change out the pedals, I've checked the service manual which is horrible. So the questions are:
How is the gas pedal mounted?
How do you remove it?
Im not sure on the evo's, and im not by my car to check it out... But there is usually just a cotter pin that holds in on to the cable.. Hope that gives you an idea where to look
The accelerator pedal arm ends in a 120 deg bend. The very end of the arm slides into a sleeve near the bottom of the pedal. After the bend (going up on the arm) there is a second connection point that is near the top of the pedal. This one is open on the top. You don't slide the arm into this; you have to snap it on. There are angled tabs that the arm snaps into with pressure.
To put a pedal on; you must first slide the bottom of the arm into the bottom sleeve. Once that is in place, you twist the pedal into a position where you force the upper sleeve to snap on to the arm. (To remove a pedal, read this paragraph backwards)
Caution:
It is very easy to crack the lower plastic sleeve when removing and installing. I completely cracked the lower sleeve on the RS pedal I removed. This can also happen when you put a pedal on. With the Ralliart pedals I put on, the upper sleeve was very difficult to get over the arm. When you try and force it to snap onto the arm, you’re twisting the lower sleeve. I did develop a small crack on the full sleeve (fortunately the crack didn't get too big). This was disconcerting, as I had just paid $120 for the RA pedals. I used some sand paper to smooth out the upper sleeves taps to more easily go over the arm.
Take your time, and be gentle
BTW The Ralliart Titanium Pedals are amazing. The Brake/Clutch pedals feel like sandpaper
Caution:
jknasins
12
Oct 6, 2003 11:21 PM
1999, a6, acceleration, accelerator, assembly, audi, audigas, civic, cover, evo, pedal, pedaldisassembly, removal, si
