LICP Fitment
LICP Fitment
I have the Injen LICP (I got it dirt cheap) and it does not want to fit regardless of what I do. Has anyone had this problem as well or is there a trick. It appears that they jig was a bit off when they welded it and the part that connects to the turbo is twisted a bit much. Any ideas?
Yes, it's a total ***** to do that pipe. Just try keeping both couplers loose and try it from one side, then the other. It will fit if you use enough force and creativity. Also, torque the **** out of those clamps. Good luck!
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Also, does anyone know where I can pick up some strong clamps today? Mine are all stripped out. Will clamps from home depot work ar are they too weak?
