spark plug cover cracked???
Old Jan 18, 2008, 09:33 AM
JordanS4's Avatar
mine cracked on the bottom right as well. seems to be a common issue.
Old Jan 22, 2008, 01:02 PM
amstel78's Avatar
Wow... so I'm not the only one. Noticed this yesterday as well. Mine is cracked along the mounting bolt holes on the right side near the sensor. It's even warping upwards!
Old Jan 28, 2008, 09:49 AM
damie45's Avatar
I just noticed that mine cracked today also, at the bottom right corner. I think its the rapid changed in temp. It was -4 degrees last week and its already in the mid 40s already today. I guess its time for that arc i've been longing for, atleast I got a reason to get it. Too bad they r sold out at the lancershop.
Old Jan 28, 2008, 10:41 AM
EvoJoeIX's Avatar
did an oil change yesterday and noticed mine is cracked too
never touched it either
its cracked completely in half on the side near the battery. maybe it has something to do with the cold weather? is this happening to just people where its cold at?
Old Jan 28, 2008, 11:25 AM
evo8nyc's Avatar
yeaa same thing with mine its the rapid change in weather its more common in the colder area
Old Feb 12, 2008, 12:32 PM
EcrsEvo's Avatar
wtf this is lame! i noticed it 2 days after a dealer oil change and im in cali no -4 temp here!!
Old Feb 12, 2008, 01:02 PM
RIKKER's Avatar
This should be covered by Mitsubishi. Call the dealer and have them order a new one. I do not think it would be temperature related I drove to canada this winter and mine survived. It may be a Torque issue with the screws I would not tighten them very much. thanks for the heads up!!
Old Feb 12, 2008, 06:32 PM
SilvrEvoIX's Avatar
Same crap here. I Gorilla Glued that sucker. So far so good.
Old Feb 12, 2008, 07:21 PM
phabaznbro's Avatar
my did the same, it was definately a thermal crack, can't explain the warm weather issues but thats what it was in my case, it doesn't have to be from cold to hot..it can go from hot to cold too...say if you are running your car then get a car wash...vented hood...not so good
Old Feb 12, 2008, 08:39 PM
EvoJoeIX's Avatar
well you gotta think how hot it gets under your hood. so what if its 70 degrees outside. i guarantee that the valve cover is at least double that temp. extreme heating and cooling of plastic is not good and the plastic can only take so much. im sure being in a warm climate it will take longer to crack, but this seems to be a very common problem
Old Feb 12, 2008, 08:52 PM
laxhero2's Avatar
count me on the list mines cracked because of tighten to much
Old Feb 12, 2008, 08:57 PM
whoang40's Avatar
probably overtorqued, crappy plastic (call mits.), or a large difference in temp if you're in a cold area. PM me if anyone wants an evo 8 spark plug cover. I need to get rid of it. Sorry to jack the thread.
Old Feb 12, 2008, 09:22 PM
skiracer's Avatar
Mine cracked, so i got an aluminum one from RRE to replace it. I also powdercoated it glossy black
Old Feb 12, 2008, 09:29 PM
Jameson_IXMR's Avatar
Never heard of it cracking like that, strange!!
That RRE one looks pretty sweet though, I think I may get that one! Thanks for posting that pic, got any more?
Old Feb 13, 2008, 09:47 AM
Kdash106's Avatar
wow, lol i thought i was the only one with cracked spark plug cover. when i just got my evo last year during the winter, damn thing cracked for no reason into 3 pieces. i went to the stealership and they replaced it for me .
Quick Reply: spark plug cover cracked???
