new to evo...... 3 lights lite on traction...
hey guys i have a question i am having problems with my traction control when i start my car only one light is lite on my guage cluster and when i start driving all three light on the cluster light up. has anybody ever had that problem? if so what did you do?
You mean the Tarmac/gravel/snow lights? All 3 lights lit indicates a problem like air in the system or maybe low fluid perhaps? When you first start the car all three lights come on for a second then one remains lit.
only one light is on when i turn the car on and when i start driving then all three light turn on...... sorry and yes the acd is what am talking about new to this car always had a honda didnt have to worry about different traction settings haha
Try checking the fluid, the reservoir is next to the drivers headlight, otherwise you may have to bleed it. Has it had a clutch job recently? If so, air may have entered the system if the ACD fliuid line was disconnected from the T/C. There is a process involving either applying voltage to the pump itself or using the ignition key and bleeding it using the nipple on the T/C im not sure though exactly how. Search the forums on how to do it OR...take it to mistu. Good luck bro.
EDIT- didnt read all of skywarps post sorry
just take it to the dealer and they will reset it for you. mine is doing the same thing. i believe i read somewhere that it has to do with the acd over heating. at tempratures above freezing (ambient temps) all 3 lights wil come on, but if it is below freezing only one light will stay on and you can scroll between all 3 settings or atleast that is what is happening with mine. it is not as serious as you think, just look it up in your manual.
At temperatures above freezing, you should still be able to scroll through the 3 settings. The Evo is not a "winter only" car.
