Going to take a look at an Evo, could use some advice...
I'm in the market for an '06 Evo MR and am going to take a look at a couple of them tomorrow. I've searched the forum for things to look for when buying a used Evo, and would like to run my list by you guys to see if I missed anything.
Any advice is much appreciated!
Visual Inspection
- Body inspection (panels lining up, paint consistency, condition of plastic/CF bits)
- Underhood inspection (looking for signs of de-modifications, like capped T-joints on vacuum lines, worn bolt-heads, scratches, etc)
- Interior inspection (enough said)
- Wheels and tires
Test Drive
- While engine cold, listen to tappet noise, and if there, ensure it goes away as engine heats and oil gets everywhere.
- Once warm, check gearbox for smooth engagement.
- Listen for driveline noise at various speeds, acceleration in corners.
- Listen/feel suspension as I drive along...for noises, knocking, etc.
- Clutch check: go WOT in 4, 5, or 6 gear (higher the better, depending on what the dealer will let me do...this is obviously on a highway) make sure it doesn't slip
- Boost check: go WOT in 3rd gear and see what the boost gauge will do (should get to 1.3-1.4 or thereabouts) (I like 3rd because I'll have more time to glance down at the gauge than 1st or 2d, and will be going slower than 4-6, making me more comfortable staring at the gauge rather than driving) (again, highway)
- Brake check: hit the brakes hard from however fast dude will let me go, make sure there's no vibration (and I guess nobody behind me) (he'll LOVE this one)
Other than CarFax, which is already done, I can't really remember anything else.
Is this a pretty good inspection?
Visual Inspection
- Wheels and tires
Test Drive
make sure it doesnt make this noise while cruising.
http://youtube.com/watch?v=TXbisxnAW-s
APM Racing
Midwest Region
Mar 18, 2014 07:58 AM
metaphysical
87
Apr 9, 2008 06:22 AM
belizelittle39439
Jul 4, 2007 09:21 AM
