Help with a/c and heating problems
Hi all i need some help here. When i turn the blower knob to any setting the a/c light lights up no matter where the temp is set to. I can't deselect the a/c button nor can i select the recirc button either. When it is in the heat range it still blows heat fine but both of the fans are always on and never turn off unless i then the blower speed to off.
Ive swapped both the relays and the same thing happen. And i pulled the ac fuse and still the same thing and the light is also on with out the fuse.
Any help would be great
Thanks
Thanks
