evo IX ecu change
evo IX ecu change
hello
I have stock evo 9mr 2006,mods only new exhaust system and I want change original ecu with br350 racing ecu.do i have to change there something more? Or its okay for just street car.May it damages something?
Its actually the same "ecu" just the tune that is loaded/flashed onto it is different I imagine. Pretty much you need to get your car tuned? There is a whole lot of threads on this website to help you tune it yourself, as well as a great deal of people who can tune it for you, that would be the safest bet.
The Br350 maps I believe are done individual for each car, so you wouldnt really get something optomized for your car.
Works has defined maps that they can flash into an ECU if you use their upgrades, and they have done a lot of dyno testing so they can probably give you a map for whatever exhaust you have installed. They have a way to hold boost on the stock turbo all the way to the redline. I just got their stealth TBE, throttle body, drop in filter and their P2 ecu flash. My car is just stupid fast now. I had considered cams and a turbo, but until I get a lot of track time I don't need them.
yes there are a lot of tuners here in this site. first off you should buy the cable. You can get it at tactrix.com. you can also get it from the evoscan site. http://www.limitless.co.nz/EvoScan/
you can then download a datalogger. evoscan has them for $25 or if want something free you could get mitsulogger http://www.aktivematrix.com/forum/dl...ile&file_id=35
after learning to log you can get ecuflash http://www.openecu.org/index.php?title=EcuFlash
Actually, you should go to the ecuflash section of this forums and read through the sticky threads and learn more. https://www.evolutionm.net/forums/fo...play.php?f=179
