still only boosting 12lbs????
heres the quick run down
https://www.evolutionm.net/forums/sh...d.php?t=324963
i swapped the 2 lines at the wastegate solinoid, but its still running only 12lbs....
ok, on one line there is a t-fitting that goes to the wastegate actuator and turbo... if i put these on backwards, would it effect that? someone said there is a pill in the line... first, what is a pill, and second, if its on the wrong line, will it effect this?
the pill is simply a restriciton in the line. it will change the readings of the vaccum or boost that is actually happening. i have an aftermarket pill in the line of my evo 8 so i can just adjust my boost using ecu flash and do not need a mbc. i just adjust wastegate duty cycle.
also do u have a boost leak. what bov r u running
Sounds like you have a hole in the lines or are missing the main restrictor pill.
The pill is on the compressor side (the black pipe off the compressor housing)
With the OEM line assembly. The hose off the T that has the red marking on the end goes to the wastegate actuator, the other line off the T with the pill in it goes to the compressor outlet pipe. On the other side, the line with the white dashes on it goes to the top port of the boost solenoid and the other side of the dashed line line goes to the turbo intake. The other hose with the metal clip on it goes to the bottom port of the boost solenoid (closest to the plug) and the other side goes to the T referenced in the first part of this paragraph.
Are you using OEM lines?
I've seen evos hastily brought back to stock with standard vac lines with a T. That will make it just run wastegate boost like what you are experiencing.
Casey Robertson
Jan 29, 2016 03:59 PM
