whats wrong with my baby
hey everyone...i had jus ordered a fidanza clutch cause i thought my clutch was goin out...whenever id hit 3 grand or when i hit boost it would happen....i took my car yesterday to my mechanic and he tested the transmission he said everything was fine and yes i still do have the stock clutch...what could it be a boost leak..note i have a boost controller test pipe and kandn air filter....any help would be appreciated..thank you
symptoms of a failing clutch are simple. At usually higher gears under heavy load your motor starts reving quickly and you car doesn't accelerate. IE you get to 6000 RPMS in top gear and are able to maintain 60 miles an hour. That would mean you clutch is most likely slipping, but there can be a couple other causes. When a clutch gets really bad you can complete release it and hold the brakes without the car stalling. I have seen some really burnt clutches. but Just be cause the car doesn't go doesn't mean that your clutch is bad. suspect a faulty clutch as one of the last things.
ohh yeah...
Elaborate.
ohh yeah...
Elaborate.
