Question about instrument panel
I just finished my retrofitting of the stock fog light switch into my ix gsr. I was wondering if there is a wire i can tap into behind the instrument cluster that will light up the fog light indicator or if there is a wire behind the steering wheel or dash i could get to easier. If anyone has a pictures of the back of the cluster or if they could point it out that would be great. Thanks
Well, uh, back on topic. Anyone know if its as simple as gounding a wire or applying voltage to get the indicator light to work? One member here replaced the whole front harness and got it all to work but im looking in to more of a simple and cheap approach that isnt as permanant.
for a non-permanant fix you can go to your local auto store and pick up an (add a fuse), http://www.tessco.com/products/displ....do?sku=469004
you will need a volt meter and then you can poke and prod around your fuse box under your dash until you find a switched 12 volt power supply(switched meaning it switches on and off with your key in and out of the ignition. as for a ground try the frame behind your dash, or you could go all the way to the negative terminal on your battery
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
AFAIK:
03' 04' "GSR" = HID/FOG
05' 06' "GSR" =Crappy headlights=NO HID/NO FOG
all SE's = HID/FOG
all SSL's =HID/FOG
all MR's = HID/FOG
all RS's =Crappy headlights=NO HID/NO FOG
Griffin2020
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 27, 2010 01:04 PM
