Car Jump!!!
Car Jump!!!
Let me start this off by saying that i've searched and searched and found nothing. To the point... My car feels like it jumps every time i switch gears. It's extremely annoying. This doesn't happen much when I'm going into 4th or 5th. I need help on this asap... Anyone?
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Could it just be the synchronization of pushing the clutch petal in abd pulling it out of gear? Sometimes when i get lazy shifting ill start to pull it out of gear before the clutch is fully disengaged and it will feel like its jumping a little bit? Evos seem to be more picky about the way you shift that most other cars...maybe its because of the awd?
Check that your pipes arent leaking. A boost/vaccuum leak could cause this. When you shift the diverter opens dropping the air back causing a pressure surge (slight) in your intake, could be loosening the couplers. Then when it dumps and you resume in vaccuum, the leak in the intake plumbing could cause a little lean condition before it is corrected and make you jump a little. Happened to me before. gl
