Oil Pressure, Oil Temp, or E.G.T. Gauge?
Hey guys. I cant decide on my 3rd gauge I want to buy. I'm going to order a AEM Wideband and a Boost Gauge but cannot decide on the last one to buy. Which gauge do you belive is most important? Oil Pressure, Oil Temperature, or Exhaust temp? Thanks a bunch
You technically have an oil pressure gauge, the only problem is when that light comes on, there could be a serious problem. It depends how far you are going to take your car, either gauge would be good to have.
I personally have 7 gauges: aem wideband, boost, egt, oil pressure, oil temp, fuel pressure, and volt.
I will be making 600+ hp so in my situation i need to know what is going on.
Quick question again, if i pick up the oil pressure gauge, i know i need a adapter/sensor. Lets say I pick up a Greddy Oil Block Adapter or GTspec Oil Sandwich Adapter, is that all I would need?
yeah the greddy oil filter adapter should be the only thing you need cuz it comes with gaskets and the right spindle for your filter to screw that's if its vehicle specific, I run it with my my oil pressure sensor and it hasn't leaked, only problem is that you have to realize that it drops your filter a little lower, I have the carbing underpanel for my car to protect it my engine bay from the bottom side and it sits a couple of inchs away from the filter after I installed it
after that jus gotta figure out how to wire the sensor down there, and make sure you have the right sensor thread for both the sensor and the block adapter, like 1/8pt won't screw in to well with a 1/8npt somethin like that
If you're going to do the oil pressure gauge and plan on mounting it next to the filter on the housing...I HIGHLY suggest you use the AMS sending unit SS braided line. They send it to you with the exact fittings to match the block and the aem sender. I bought this line from them and haven't had a single issue with it.....I will post pics when I get a chance.
Jorge R.
Jorge R.
[WTB] AEM 50PSI boost gauge
needsboost
Mar 7, 2016 10:18 AM
Profoxcg
Oct 1, 2007 07:26 PM
