EGT (pyro) question !!!
Old Mar 13, 2008 | 03:50 PM
raymi's Avatar
what would be the safe exhaust temp reading for a 500+ hp evo running on pump gas ???? any ideas ?
Old Mar 13, 2008 | 04:02 PM
MR Turco's Avatar
EGTs are transparent to HP. Do you have any top end work done? Where did you put the probe? If you have a stock motor i would say 1650 is where you want to max out.
Old Mar 13, 2008 | 04:07 PM
raymi's Avatar
last tune was done without this gauge, but now I am thinking to put one in because my AEM wideband is acting up ! head is fully done, port/polish, valves ect...
Old Mar 13, 2008 | 09:06 PM
raymi's Avatar
helloooooooo ?????? I can really use some info !!!!!
Old Mar 13, 2008 | 09:27 PM
Dapper Dan's Avatar
If you could use the info that bad you could stop being lazy and use the search button.
Old Mar 14, 2008 | 12:22 PM
raymi's Avatar
lol
Old Mar 14, 2008 | 12:26 PM
MR Turco's Avatar
What kind of valves did you get? Sodium filled, stainless, inconel? Your egts regardless should be under 1700F
Old Mar 14, 2008 | 12:31 PM
raymi's Avatar
Thanks ! At least some people here actually help you out ! I have stainless oversized Farral valves......thanks again.......
Old Mar 14, 2008 | 12:34 PM
MR Turco's Avatar
Dapper Dan is a pretty active, helpful member of the forum so i would not try to make enemies. Good luck with your car.
Old Mar 14, 2008 | 12:40 PM
DS-03evo's Avatar
I am usually about 680-720C when cruising and about 800-850C WOT. This is on pump gas.
Old Mar 14, 2008 | 12:41 PM
Dapper Dan's Avatar
thanks! I try to help when i can.
Old Mar 14, 2008 | 12:45 PM
rcheung's Avatar
I never really understood why people were so lazy and dont even attempt to use the search button. Has our society really at the point of being ignorant and not able to help themselves or am I just really proactive and search first?
Old Mar 14, 2008 | 12:53 PM
MR Turco's Avatar
I dunno. I personally search like crazy when i can because i tend to find threads where additional questions are asked that i wouldnt have thought of. But i sometimes find that searching can be fruitless. Searching is a skill that can take some time to figure out though. Not all of us live here so you have to let it go sometimes.
Old Mar 14, 2008 | 01:09 PM
raymi's Avatar
im pretty sure he is....but i just respond to what i am told....
Old Mar 14, 2008 | 01:10 PM
raymi's Avatar
im pretty sure you do.......
