engine starting problems and keeps stalling
Ok i have a VIII with a Aem intake, TBE, 272 cams and gears, MBC 21psi, i had the car tuned and it was working fine. I had the clutch replaced by the dealership now it does not want to start right away i have to push on the gas and keep the rpms up on it for about 10 min then it will work fine. And it stalls sometimes when i stop at a light or turn on the AC. Now i think it is because i disconnected the battery wich i know that resests the ECU or could be something the dealership did maybe. But i waited a couple of days to see if the ECU just needed a couple of days to reset itself. So would that make the tune go away? Here are the things it also might be need to know what u guys think. I did search for this too and here is what i came up with
ECU needs to be retuned because of disconected battery
vacume leak have not checked for this yet
Stealership dissconected something and did not reconect it
Bad stock injetors doubt it or they are leaking
Not sure what else it could be thanks for any help guys
No i dont have any way to do that. But with all the searching i have done it seems a lot of us have this problem. But it seems no one has found a fix for it yet. I am thinking i need to put the stock intake back on maybe its the MAF
