battery issues
Well you got a current draw somewhere what did you install or change right before you started having this problem. You mentioned gauges did you tap into a keyped powered source (turn on off with key)?
Load test the battery maybe it is just old and tired unless it is new but the load test is still a good start. Maybe a little more info is the battery new or older and when does it die overnight or a quick run into a store?
