Is it worth installing Injen LICP?
Plus a billion, but more importantly make sure that your couplers are long enough the stockers are a little too short to get a good bite on the pipe. I blew off my LICP 3 times in a week just recently and solved it with longer couplers and T-Bolts. Definately do the T-Bolts if you are running higher than stock boost.
Also make sure you wipe down the ends of the pipes with alchol (not the drinking kind, ha ha)
Here's my list of upcoming parts that'll be on order:
eBay 3" DP
eBay 3" HiFlow Cat-delete
eBay Walbro 255 lph fuel pump
Apex'i SAFC II or Neo
Swoosh boost gauge
Hallman MBC
AEM wideband A/F
AMS tuned....
As far as I know, that's it. When I bought the Evo, it already came with the Works exhaust. My first mod was the Injen intake. Because the LICP seem to be the same as the OEM, I decided not to put it on but after all the good comments, I made a little mod to the Injen LICP and will install it on Sunday if the T-bolt clamps is here by that time.
T-bolts are on the way. Hopefully it'll be here by Sat so I can do the LICP on Sunday. I always wanted to go with brandname like HKS, JUN AMS and they recommend the Apex'i SAFC neo. I wonder if it's ok if I get the 2nd black version instead.
eBay 3" DP
Swoosh boost gauge
Hallman MBC
AEM wideband A/F
AMS tuned....
eBay 3" DP
Swoosh boost gauge
Hallman MBC
AEM wideband A/F
AMS tuned....
Also any particular reason why you are buying top notch parts and then eBaying the rest???? eBay Walbro??? Do you mean a Walbro you got off of eBay? MBC is a good choice, AEM wideband as well I am looking to get one myself. What do you mean "I always wanted to go with brandname like HKS, JUN AMS" ???
