compression test = uh oh
So i got the cob stage 2 last week and installed it. car spools great but at around 5k -5500 the car would start to sputter and then the fuel would cut. i have a mbc so i turned it down a little with the same results. i did research on the ap forum and found that alot of people were experiencing this and i need to call cobb. Well i got the idea to do a compression test just to see if everything was A OK. Well... its not. i followed the manual instructions to the "T" and here are my results:
#1 155
#2 130 135 w/ alittle oil
#3 165
#4 165
Yes you are seeing that correctly. I have ring issues with #2. This is not good (obviuiosly) anyone have an idea how much and how long to get this fixed by the mitsu dealer. There is no one around my immediate area as far as shops go.
#1 155
#3 165
#4 165
To be honest I wouldn't have mitsu. fix it. Also you may just want to be easy on the car for a while and save up and just build the motor, especially if your going to mod it anyways.
I had my Rod and Crank Bearings replaced, along with new Rod Bolts and a little polishing to the crank. This was at 18K and completely stock, with records of oil changes every 3K. James Reese was the service tech. at El Cajon Mitsubishi at the time, and worked with the Rep. on the 100% covered warrenty.
true. where would be a good place to do that? what the dealership be good. I am very disappointed right now and can't think straight. I mean i only got the thing in december. Starting to wish I hadn't
