Will I be ok?
aftermarket fmic will help a bit on hot days, not sure if you will gain any hp, MBC would be good. I would go with same option as you did, since later on you dont need to worry about upgrading your fmic if you decide to go with more mods.
i dont think u woudl get any gains, is the IC really large?
i have driven a stock Evo 7 with an upgraded IC and it was experiencing slight boost lag comepared to before.. nothing major u will be fine....get some pics up....
i recently got into a bad accident myself and wanna fix back my car, the IC, radiator and air box are damaged!
Had the AMS fmic and lower pipe on my car for about a year. Still looks like it did the day I took it out of the box. I had very little pressure drop if any and about the same spool up. As for power I would say 5-15whp depending on your mods.
blackvii
23
Nov 18, 2004 03:47 AM
