what can i use from my eclipse?
im looking to sell my eclipse, soon, and buy an evo. i was wondering out of this list what can i use on the evo.
625cc injectors
profec B(im sure it will work)
afc(should work right?)
hks 272 cams and cam gears, i havent even installed yet.(i heard they have different part numbers but are they the same?)
walbro 255 fuel pump
greddy type S bov
thanks
625cc injectors
greddy type S bov
thanks
The DSM 'G63 is an older version of the the current motor. Some research was done on it and you can look most of it up, especially the cams, but it's been determined not to much is capable of being ported over.
yea i figured that most stuff couldnt be ported but i was really wondering about the stuff i mentioned. anyone know where i can find the info or just tell me from that list of stuff what will fit? thanks
1 Post
i'm sure u can make the BOV fit, AFC and boost controller will work. Injectors will work as long as they are bosche style, which they should be, and the cams will not work. The grin is the same but I think physically the cams are different. Fuel pump will work but I find no need for it. I don't tihnk you will need much of the parts you have other then the afc and boost controller. BOV if you want (will need a little fab)...
