Evo won't start!!!... HELP!
So my Evo hasn't reliably started for about a year now. I'm pretty over it. I'll think I have it figured out, then it just won't start again.
Symptoms:
Car will run fine for random amount of time, 2 days to maybe 2 months. I will go outside to go someplace, hop in my Evo, and turn the key. The car will do 1 of 2 things. It will either start right up, no problem, and then just cough and die, or it will just turn over forever and never fire up. Either way, it will never fire again for a LONG time-- often weeks. I have tried removing the battery, resetting the ECU, changing the ECU (as in getting a whole new one), changing the main fuel relay, changing the fuel pump, ect. We've hooked up the MUT tool on it and when it used to say that the ECU and the Immobilizer key weren't speaking right-- their sync was off or something. When the MUT would read this, the little green key symbol was lit on the dash but didn't sound like the immobilizer was killing it. Now the key symbol is NOT there-- it just DOESN'T START! Works checked the plugs after the car wouldn't start for a while and they were DRY after we tried to fire it up. But the immobilizer kills ignition right?
Every now and then when its dead, I'll walk outside, say a prayer, and turn the key. RANDOMLY it will fire up and do it reliably again for, as I said, a COMPLETELY random amount of time until it leaves me stranded again!
Neither Works nor the dealership can figure it out. Has ANYONE had this issue? Its REALLY annoying. Right now I have a $30,000 pile of scrap metal sitting in my driveway that feigns usefulness before it leaves me in inopportune places at very inconvenient times. This is REALLY turning me off Mitsubishi that they have a very complex electric system but don't have the diagnostic tools to fix an inconvenience like this.
I'm so over it, please help!
I may even take some video later to see if that helps.
Symptoms:
https://www.evolutionm.net/forums/sh...ater+corrosion
Well that thread didn't have the best description but do a search for corrosion. It is behind the drivers side kick panel and check all the harness's behind it. Mine looked great but many have had green corrosion and electrical problems due to it.
^^ I have a whole sticky with numerous threads about the corrosion issue here
https://www.evolutionm.net/forums/sh...d.php?t=323902
May be related but im not sure how much water San Mateo sees in a year and typically you'll have issue with dash functions (Lights Staying on, Wipers going nuts, Relays clicking) long before a no start situation but its certainly possible
Its deffinatley something with your ECU it sounds like...but at the same time it sounds like a looose wire somewhere...because sometimes it works sometimes it doesnt....meaning its probably on your ignition somewhere
Evo_Goodness
Aug 3, 2016 04:20 PM
shadovarian
May 1, 2012 08:31 AM
akeric
Jul 31, 2011 08:45 PM
