quick question??
quick question??
Hey guys... Im going to be buying the 3 inch catless downpipe with electronic cutout from QTP (quick time performance). My mods will be ... AEM Short ram intake,forge mbc, walbro 255... and i want to get dyno'd from Sean Ivey when I put it on. I just want to make sure that when I get dyno'd for the cutout open... and when its closed, driving on the street... will there be any damage to the rest of my stock exhuast? Will running rich from the cutout tune with the cutout closed destroy my cat converter? Explain to me what the rest of the exhaust willl have ater the QTP dp? Thanks guys!
here is smokedmustang's thread..
https://www.evolutionm.net/forums/sh...=178605&page=2
Thats in his scenerio... I am also going with the qtp dp because I cant have a loud exhaust on the street... But I want to be tuned FOR the cutout open. And for the most time.. keep it closed. I live in a rough state I can't afford loud exhaust EPA tickets.
I didnt mean to be hostile before by the way... I've seen cat's vaporize from being too hot etc etc... I just dont want to have to replace it. So once again... If I go with the 3 inch elec cutout from QTP... I can hook it right up to the stock exhaust. Tune it for the cutout... Close the cutout. No problems? Thanks for your posts!
It depends on where you hook up the OTP, and where it is in relation to the O2 sensor which will determine if it will run OK. The O2 might send a wrong message to the ECU, causing it to run differently. Hope this helps. Let us now if you get any gains on the dyno.
It depends on where you hook up the OTP, and where it is in relation to the O2 sensor which will determine if it will run OK "
No no no... I will be getting the new QTP catless downpipe w/ the electronic cutout all in one... Its not just the QTP electric cutout you weld onto your exhaust.
10isace
75
Jun 9, 2015 05:45 PM
anthonyrb98
Nov 8, 2011 07:03 PM
