Question about Evo.
Question about Evo.
I may be buying an 03 EVO soon. This evo has a lot of mods and upgrades. Im wondering would all these mods require a lot of upkeep? because this car will be used as my daily driver. here is his list
EVOLUTION MODIFIED. GT 35R WATER COOLED TURBO WITH HIGH PERFORMANCE GLASS COATED MANIFOLD. OIL COOLER THERMO FAN. LARGE 3'' OPENING INTERCOOLER. HIGH OUT-PUT IGNITION BY KHS. SUPER SMALL DRY CELL BATTERY BY ODYSSEY. DUAL COLD AIR INTAKE WITH FREE FLOW AIR FILTERS. LARGE 4'' INTAKE FORGE BLOW OFF VALVE. NO. 8 SPARK PLUGS. HIGH STRENGTH HEAD BOLTS AND GASKETS. HYPER GROUND SYSTEM. HAWKER BRAKE PADS (45% more stopping power). NEW 245 X 17 TIRES. WATER INJECTION WITH 100 LBS PRESSURE PUMP. 150 HP NITRO SYSTEM. REMOTE NITRO BUTTON. LARGE 3'' EXHAUST KIT BY HKS. EGR METER SYSTEM. FUEL PRESSURE GAUGE INSIDE AND OUTSIDE. MANIFOLD TEMP GAUGE FOR BEFORE INTERCOOLER AND AFTER. AEM ENGINE MANAGEMENT WITH 3.5 BAR PRESSURE SENSOR. HIGH PRESSURE FUEL PUMP. OIL BREATHER TANK. 720 CC INJECTORES. HIGH BOOST GAUGE WITH VACUUM. WIDE BAND METER SYSTEM. TURBO TIMER. ADJUSTABLE FUEL REGULATOR. AUTOMATIC BOOST PRESSURE ADJUSTER. SHORT THROW GEAR SHIFTER. ORIGINAL OWNER. OVER 600 + HP TO THE WHEELS.
i wouldn't buy it. first it is probably beat to **** and second he calls hawk pads hawker pads. the second one just bothers me. what's a khs ignition? or a dual cold air intake? nitro system?
well the dealer selling it has no ****ing idea what he is talking about first off. they always do that crap. second i would not buy a car that highly modified unless i knew the person sellin it personally and was sure the car was properly taken care of in the first place
the lack of drivetrain talk scares me too...
get yourself a nice 9 as stock as possible like everyone's advising. i bought a used 03 from a mom and pop shop 2 years back and it was nothing but a headache for the first couple months. I knew it needed some work, but not as much as i thought it did. I had to replace everything from the damn door hinges to the sunroof. The damn shift knob even flew off while i was shifting to fourth...literally flew off...so, yah...be careful what you buy...no need spending money on things that could have been avoided, let alone on something so "highly" modded... if its stock you'll know no ones really f*cked with it.
