Anyone have a trailer hitch on their Evo?
Old Aug 12, 2013, 06:59 PM
  #76
Tachyonzero's Avatar
Originally Posted by Evilution23
sorry Evos are bred from RALLY CARS. Towing looks dumb on them. unless you have a crossover, SUV, or a subaru stationwagon (theyre a little heavy dutier than most) you should not be towing ANYTHING with a car. all the excess weight moving will shock and cause stain on the drivetrain leading to problems
Lawl
sorry for resurrecting the topic. do you have any webstore to recommend a tow hitch for the evo?
Old Aug 12, 2013, 09:18 PM
  #77
TrippinKent's Avatar
CBRD- they can make you a hitch.
other than them, I haven't found a person or place that make something specific for evo's.
Old Aug 13, 2013, 04:02 AM
  #78
cs82685's Avatar
Since it's been bumped, I thought I read in another similar thread if you find a hitch made for a regular lancer it will work
Old Aug 13, 2013, 11:18 AM
  #79
CBRD's Avatar
yes we can help-
cb
Old Nov 9, 2013, 03:49 PM
  #80
jono2626's Avatar
Im in need of a tow hitch but I am located in Australia. Is there anyway to custom fab one up?
Old Nov 9, 2013, 06:53 PM
  #81
hatesposers's Avatar
OK, I am one of the few that's actually done this. I have responded to other threads, but it seems that there's always a new thread without this information.
First of all. Here's a picture of my car with the trailer. Now while it looks like a heavy trailer, it's less than 125 lbs, and fully loaded with everything I put on it, it's just under 1000 lbs. The tongue weight is about 80 lbs fully loaded.
Now, here are the FACTS...
pulling a mild trailer with an Evo is FAR LESS strain on it than launching. Drive smartly, don't ride the clutch, don't rabbit start/stop with it, and you will be FINE.
If you have a USDM rear bumper, there is a member on here, who sells a hitch kit which ties into the crash beam, and the differential support. It is EXTREMELY stout, and is nice.
If you have a JDM bumper style: There is no BOLT ON trailer hitch. The base lancer hitch is NOT BOLT ON. I repeat. previous threads which state this are WRONG!
I have spoken to savaho AKA this gentleman:
and while he got the modified hitch to bolt on. it was very weakly mounted, and caused flex that would have eventually ended up in failure. He E-mailed me after I had done mine, and he came up with the same solution as I did.
Here is my solution:
I purchased a U-Haul (made by Curt) hitch for a 2003-2006 BASE lancer.
I purchased a piece of 3/16" cold rolled steel plate 4' long by 8" wide.
I cut off the middle top stabilizing support of the hitch (which would go to the factory bumper on the base lancer.
I then used the crash beam to mark drill holes on the cold rolled steel plate.
Drilled the mounting holes in the steel plate
sandwiched the plate between the factory roll pan, and the crash beam. Bolted it in place.
I then mounted the hitch to the rear tow hook (as per U-haul instructions). And lined up where the top supports met the steel plate. Marked locations on steel plate.
Removed everything from the car. Drilled mounting holes for the hitch on the steel plate. (I then cleaned up, the edges of the steel plate, and painted)
Mounted steel plate and crash beam to car.
Mounted hitch to the tow loop, and steel plate.
Put JDM bumper back on and TRIMMED TRIMMED TRIMMED so that the tow bar clears.
That's how you fabricate a hitch with the JDM bumper, and what you need.
Old Nov 10, 2013, 03:54 PM
  #82
Ive had pm requests for the forum member who makes hitches for the usdm lancer. His screen name is 91tsiguy
Old Dec 20, 2013, 11:40 AM
  #83
Musclebob26's Avatar
This helped me with my hitch.
http://www.hitchanything.com/towing-safety-guides.html
Old Dec 23, 2013, 11:15 AM
  #84
vile's Avatar
Random bump -- CBRD.. I contacted you guys through your site.. looking for a custom hitch for my Evo X -- you guys are about an hour away hopefully you can help me out
Old Dec 24, 2013, 02:42 PM
  #85
SiriusEvo's Avatar
Lol get a truck
Old Dec 24, 2013, 03:13 PM
  #86
victorv's Avatar
im looking to do the same with my evo x ive seen pictures but want to see if theirs anyone on here that has done it yet??
Old Dec 25, 2013, 06:29 PM
  #87
letMeIn's Avatar
I will be selling mine soon. It bolts between rear crash beam and frame. The hitch sits just below the bumper so no need to cut. Ive used it to tow a small chinese trailer ( which you can usually find for cheap on ebay ) with racing equipment to and from track. Never had any problems with it, and evo can pull few hundreds lbs without any issues. If anyone is interested shoot me a pm. If you search the forum, you may find couple of pics of my white evo with the hitch attached.
Only selling because no longer need it. Evo is done towing stuff to track.
Old Jan 6, 2014, 04:35 PM
  #88
drewbird91's Avatar
Figured I'd throw some stuff in there to link to other helpful threads. I made a trailer hitch for my Evo 8 with JDM rear following this thread: https://www.evolutionm.net/forums/we...er-set-up.html
Here are some pics:
I followed this post (#5) to do the wiring:
https://www.evolutionm.net/forums/ev...connector.html
Old Jan 7, 2014, 11:03 PM
  #89
OSiRiSNZ's Avatar
Old Apr 11, 2014, 05:55 PM
  #90
99civicsi's Avatar
Bump, anyone else tried this? I want to see pictures!
nicekyo
Dec 28, 2017 01:26 PM
DSMolition
Jun 25, 2015 05:47 AM
mayhem
Automotosports - Illinois
45
Sep 25, 2011 06:50 PM
trboboost91
Nov 10, 2007 12:31 PM
Quick Reply: Anyone have a trailer hitch on their Evo?
