Help car wont shut off
Started off with the turbo timer flickering.
Then the car battery died after a couple days of not driving.
Then eventually the car wouldnt shut off. even when I pulled the key out.
I figured it was the turbo timer so I Brought the car to the alarm place that installed my car and they disconnected the apexi turbo timer. Still no luck as the car wont shut off. I shut the car off by stalling and disconnecting the battery. HELP!
Mods: flash, apexi turbo timer, cams, bolt ons.
*Update* problem solved
1 Post
lol that car is ment to be driven, listen to the car, DRIVE IT!!! its a transformer. jokin,
But all jokes aside, I think this might require dealer attention, if its not responding to a ignition cut.
well i hope its not what happened to me. my car would not start at times, the immobilizer was kickin on for some reason....battery kept dying....horn would go off for no reason....
anyway, took it to the dealer. they started it, and it would not shut off. turned out being corrosion on 2 harnesses. i ended up getting a hell of a deal, but thats only cause they messed up. yours is 2 years newer so i'd hope thats not what it is but theres a chance i guess. good luck with it.
You problem have a wire that is grounded. You need to check out your wiring to ensure that you have no grounds that would cause your car to continue running. I would say it may require taking into the dealer for them to find the ground.
problem sovled. Thanks fellas. It was that harness. The white harnesses had green corosion and rust. F-ing car is only 3 years old. Anyways 350 bucks later problem was solved.
Another member on here went the route you did, and then still had problems shortly after. Having worked in electronics and cable building before, replacement of corroded wiring is best fixed by replacement. I hope it works out for you.
Just make sure for you guys that are replacing your harnesses to seal up that darn grommet.
I agree that cleaning the contacts is reall not an option here. You really need to hard solder all the connections. The damage to the exposed portion of the wire is already done making it very brittle. so cleaning off the pins is still leaving you with brittle pin connection.
Cut the wire back a little and hard solder them. You'll never have an issue again
03lan-evo
15
Apr 11, 2009 12:36 PM
